Battery RC and sound (PWM)
CoggesRailway
8
Today I fried by Brian jones class 37 sound card I was fitting to my 2095. It was user error. but I had it working long enough to realise it didn't properly behave with the cliff barker RC kit.
I am not interested in reproducing the prototypical but naff noise these make in real life. :D
Anyone got some ideas here for a replacement. I know there was a a similar thread but this is different as the speed control is PWM not analogue. the battery is 14.4v.
I have emailed cliff for his thoughts. Thanks in advance for your help.
CoggesRailway
8
PM sent Mel. Still need a solution so any thoughts people?
Rhinochugger
Retired Oik
4,247
North West Norfolk
I'm in the process of installing one of Richard Rix's Trax Controls diesel sound cards in a battery conversion.
the sound is basic, but so is the price :rofl:
I've used one of his steam sounds before, and there's plenty of adjustment to get it just right.
They run off a separate 12v source (and it has to be separate) but it can be AAA.
:D:D
Moonraker
132
South Australia
The MyLocoSound diesel soundcard works well with Cliff Barker's radio control. In fact, if you contact Cliff he can supply the soundcard and also a customised set of instructions for use with his system.
Regards
Peter Lucas
MyLocoSound
Madman
2,987
Pennsylvania, USA
Ian,
Have a look at this site, http://ittproducts.com/
I have the "Diesel Helper" card in one of my trailing cars. I use it with my smaller diesel locos. As you know, I use the G Scale Graphics system, which also uses PWM. The sound works perfectly. George will make any sound card you want. All you need do is send him a recording. There is no extra charge for this service. He has specifics on the type of file you can send him. His email address is on his site.
MRail
16mm etc - Live steam, battery & trams
3,365
37
Merseyside, U.K.
youtube.com.user.MadogMersey
Apart from whether it's suitable etc, Brian Jones can often repair user damage.
It may be worth an enquiry, you can always sell it on if it's working.
5,001
Hi mr Cogges,
I did post a bit about using the Brian Jines Sound Card, in my 2095. I use the Aristo Train Engineer Revolution 2.4 Ghz kit. Superb quality of control with the rich 37 clatter etc. Only problem I had was the Horn Sound which cannot be driven direct from Brians Card by the Revolution. To sort this (after some consultation with Brian) I put in a small relay that is operetade by the Smoke Circuit from the Revolution and all is well. Will search for my thread and put the link in if you cannot find it yourself.
5,001
Cogges,
Further to my earlier post, here is the link to my work on my Battery Conversion to my 2095.
Just a thought re your fryup of the Brian Jones Sound Card, may be worthwhile asking him if he can look at it. May be recverable.
