Hi, I did a thread maybe thre years or so ago but all the photos have gone.
I basically stripped right down above, and below, "footplate" level - then cut (20mm in from outside edge) along the length on both sides to the required dimension (100mm width).
Then I had to trim the remaining "footplate" underneath to accept the pieces I had cut off (those two pieces having the footplate and buffer beams removed.
The arrows showing the portions of the plastic to be removed.
The two engine compartments were then cut down by about 10mm - as was the cab. The cab was also lowered by 10mm then narrowed to suit the new footplate. The roof of the cab was cut into three pieces (the middle portion being 40mm wide and discarded).
Scribed, ready for cutting.
The centre portion of the cab remained the same width, as did the bonnets. The doors were narrowed as can be seen here below.
The inside had to be cut down also. The brake rigging needed some tweeks and I ended up soldering some new steps to give clearance for the truck.
The side handrails were reused but I made some new ones for the ends - the originals were cast from Mazak so did not lend themselves to modification.
