NCS from Qbyn
Interesting. We use a two step process. First you clean the area on the PVC pipe to be mated, with the cleaner. It is basically Acetone. It is usually purple in color, but clear is also available. Then you coat the male and female ends of the pipe with the glue. Once you have them both coated, you shove them together and hold it for a few seconds. That welds the two together.
Both the cleaner and glue come in small cans. The screw on lids have an internal applicator attached to a stiff wire, with a fuzzy ball of cotton on the ends. You simply use these to apply the cleaner then the glue.
We use PVC for both drainage and water supply piping. It certainly has made plumbing alot simpler than when I was building my house. I used copper tubing back then. I found myself in all sorts of contorted positions with a flame, trying not to catch the house on fire as I soldered tubing for both the water supplies and the heating system.
Those little cans of red cleaner and blue more viscous glue are used to join PVC pipes here too. In fact, I used quite a bit in my garden when I was putting in pipes for water features. The fumes are pretty potent and the red stuff seems to get everywhere and stains pretty badly. The glue does work. I've never thought of using it anywhere but on the pipes. I have tried many glues over the years and most will eventually succumb to the harsh elements we have here - particularly the UV. One glue that I did discover a few years ago seems to be more resilient than most. It is called OmniStick. It is a rather pungent and extremely viscous glue that comes in tubes. It is made in the US and seems to be sold almost exclusively by an outfit called Ozark Miniatures. It will stick to almost anything [hence the name], except shiny ceramic tiles or smooth glass. [It will even stick to these initially, but eventually the rain weakens the bond]. It hardens almost clear and maintains a small amount of plasticity. I use it for heavy duty stuff, like wall and roof joins. It seems to last very well. The only problem is wastage. The glue starts to set almost as soon as it leaves the tube, which means you tend to lose some to drying out on the nozzle between applications. Still, it isn't that expensive, and that feature also means the glued surfaces don't need to be clamped or held for too long before they stay stuck - although full curing is usually an overnight job. Another good aspect is that it can be washed off your hands with water and some vigorous rubbing. It is not as environmentally hazardous as a lot of other strong glues that are sold.
