Re:A very basic question and a bit more.................
HI Thanks for this. Now I know I can set up isolated section in the siding for the train to stop.
the problem I still have is that having opened the turnout into the siding with my point motor wired to my momentary box, I know I can close it once the train is in the siding via the momentary box BUT I cant see when that happens and I dont want the other train to follow it in.
I need a means of closing the point (I opened with the momentary box) after the first train has cleared it and before the second train goes over the turnout??????8|
yes, it can be done.
you need one turnoutmotor, one add-on switch for the motor, one or two reed contacts (17100) and a momentary box, if you use just one 17100. and a magnet for each loco used. (and two turnouts of course)
the siding must be isolated from the mainline.
the add-on switch is on the entering turnout. it gets current from the mainline as input, and current to the siding or nothing as output.
in the siding (a trains length from the entering turnout) is one 17100.
on contact it sets the entering turnout to the mainline and cuts off the current to the siding.
the other 17100 you put anywhere in the loop, where it pleases you. that one sets the entering turnout to the siding and allows the current to flow into the siding. (this second 17100 can be replaced by the momentary switch)
using two 17100s, the trains will leapfrog every round.
using the momentary switch, one train stays in the siding, till you press the switch.
ah, the leaving turnoutwill be cut open by the trains. if you want it to be switched it needs an electric motor too (that would be wired in paralell with the entering turnout)
[/quote]
