G gscalerookie Registered 4 Mar 2025 #1 Can the loco shed be extended after building or should be extended before assembling?
Diesel2000 Registered 5 Mar 2025 #2 gscalerookie said: Can the loco shed be extended after building or should be extended before assembling? Click to expand... Extender kit should be installed when building as it adds an extra middle section
G gscalerookie Registered 5 Mar 2025 #3 Diesel2000 said: Extender kit should be installed when building as it adds an extra middle section Click to expand... Thanks
G gscalerookie Registered 5 Mar 2025 #4 Diesel2000 said: Extender kit should be installed when building as it adds an extra middle section Click to expand... Do you know if the auto door closer can be added at a later time or does it need to be included in the assembly
Diesel2000 Registered 6 Mar 2025 #5 gscalerookie said: Do you know if the auto door closer can be added at a later time or does it need to be included in the assembly Click to expand... That I dont know, I installed servos to control doors and did that during the build before attaching the roof.
SevenOfDiamonds Registered 6 Mar 2025 #6 gscalerookie said: Do you know if the auto door closer can be added at a later time or does it need to be included in the assembly Click to expand... Attachments 1741270667844.png 707.7 KB · Views: 0
G gscalerookie Registered 6 Mar 2025 #7 Diesel2000 said: That I dont know, I installed servos to control doors and did that during the build before attaching the roof. Click to expand... Thanks any reason you went with servos instead?
