I notice that you have a point motor in pieces. Is there a diagram showing how to assemble one?, I had a substantial collapse on my line which seized the point motor. I took it to pieces but cannot see how to reassemble it
Ok I have pulled the all ones that I got apart to clean them up. Put together process:-
Put bottom of Motor with deep bit on Bench with the Wire Entry Screw Holes to the left.
Construct inside Round Parts with Magnet in Middle.
Put 2 side pieces on with the longer bit to the Right onto the Metal Poles.
Put Round assembly into the Metal Poles with the Gear to the Right. Note the small pin needs to be Uppermost this is what stope the Motor using the Side pieces.
Put the assembly into the Bottom with the Gear to the Right.
Put the Cross Gear Train onto the Gear (this is the part that moves the point blade). It should be either one side or the other ALL THE WAY SO THAT THE END TOUCHES THE OUTER CASE. THE LITTLE SPIGOT SHOULD BE THE SAME SIDE.
Put the top on and test with power holding the top on.
If all works OK you can screw the too on finally.
If there is a problem look at the Connection under the wire entry to see that the very smaal wire has not come off. If it has you wilo need to resolder it on.
Also the Contacts where the wires go in can be clened, remove the screws and take outbthe contacts with a pair of Tweevers. Clean up, test that you get a circuit with a Meter and reconstruct. All should be fine now if you got a circuit via the Wire Inputs.
Good luck with the rebuild. I was surprised just how easy it was to get the Motors working again. All 9 of them were faulty in one way or another with many having severly rusted pole pieces, but all work just fine now.
