Gavin Sowry
Garden Railroader, Raconteur, and Gentleman
Only just picked up on this thread. Top marks, and welcome to GSC.
Check out the one that Capt. Jack just built it is fantasticIts on my (very long) wishlist![]()
Normal procedure would be to create a passing loop. Where the Track Curves into the Station on the left would apear to be the place to give the longest one possible. As your Track apoears loosly laid on ballast the change should not be too tramatic. Using two points would still leave one for a couple of sidings. one train could then be pointing Clockwose the other Anticlockwise thus giving more interest. In time you could even wire up with EPL to swop Trains and direction with Electric Point Motors, Point Motor mounted switches and Isolating Sections.I've had a train running most evenings while I potter around in the garden since I extended the track. Probably the most I've used the set since I bought it. Interestingly, because I'm running it more, I'm noticing the layout doesn't actually work quite right for the way I use it. Which is basically a loco trundling around the loop, and every so often as I pass by I take it into a siding and either change the wagons or else park it up and give another loco a run out round the loop. I'm not exactly a power user!
So I've changed the routing of the sidings and isolated them all so the loco not in use has a place to go, and usefully time keeps the rolling stock placed so there is a lot less hand of god required.
I like seeing pictures of everyones layout, there are so many great ideas out there, so as usual I will add the latest of mine.
View attachment 243464View attachment 243466View attachment 243467View attachment 243468View attachment 243469
Thanks for taking the time to make these suggestions. Yes, the entire track is sitting loosely on potting grit ballast so any changes are easily made. Good job too, as I keep making them. I did consider a passing loop something along the lines you mentioned, but the downside for me is the awkwardness of reaching to the back part of the track to push the points over. As it stands all the things I need to touch are along the front of the layout. With that in mind I have been thinking about creating a place to pass along the front straight. Its a bit of a compromise I know, but realistically electric points are way down the line for me (if ever), so for now at least, everything being within easy reach is one of the things I prioritise.
