Having decided my Line is not really narrow gauge looking and having made new wagons with mainline double buffers, then i now needs a Loco to suit, so mine will be a GWR 13** Class, first image below shows a Piko block overlaid on a overall side view to get an idea on how well it would fit. At the moment its based on the Piko block as it is a 0-6-0- Loco
next image shows a very basic model of it, still a lot of work to do on it yet. It will be as much as possible 3D printed
Nice - though you should probably do a 1366 too, just to keep the 1361 company...
Most of the loco is the same, just need to model the pannier tanks.
Thanks for your thoughts on the 2093 model Jonathan! Sounds like you would like to build one.
I had a passing interest a while back, but it's not really 'mainline' enough for my tastes. Plus I have a build list a mile long.
In these days of cheap home CNC and 3d printing, I suspect a kit will eventually appear from somewhere, thought 2'6"/750mm/760mm gauges are always a bit of an unhappy compromise on 45mm track.
In a similar vein (another box on wheels) I also considered the Bo-Bo diesels on the Zillertalbahn, D13 and D14.
Not whizzy-cranks, these are fairly modern locos from Gemeinder. They were used for freight when Zillertalbahn still had freight traffic (mostly timber), but nowadays are used as the power for push-pull passenger services.
I was pulled by this one on my trip to the Zillertalbahn a few years back.
Lilliput do an HOe model.
I found a scale drawing on the Internet:
It was going to be too long for my R1 radius layout, about the same size as an LGB RhB Ge 4/4, so I tried to squeeze it down to about 450mm long with almost comical effects as shown in my attempt at a 1:22.5 scale drawing:
Needless to say it never got built and probably never will. But it might inspire another Austrian NG fan.
Remember them from when they came out, I think Continental Modeller may have published a Gemeinder factory drawing? In about HOe? I did wonder about them too, but as you say, they're huge beasts on 760mm, particularly with the standard gauge buffing gear. And if you want to scale them back disproportionately and use the LGB rubber-ruler scheme (ie width loses a bit, height about 10% maybe and chop a great chunk out of the middle for length), it can be really hard to capture the spirit of something. it usually winds up being all about subtle angles and proportions that aren't apparent when you look at the (true) scale drawing. And there's never a mech the right size either. Guess how I know all this?...
Always liked the OBB 4090 emu too, but making that would be an exercise in pure frustration. Plus I've got a feeling there was a three car and a four car variant, but just one of each - DM-T-DT and DM-T-T-DM repectively I think.
Stop press, looks like someone has built a g-scale model.
Always did like the 1099, sort of wizzy-cranks-plus.
Jonathan
g-bits.co.uk
