idlemarvel
Neither idle nor a marvel
I bought a piece of flexible MDF from Wickes to make a tunnel, and I had a few ideas about how it could be used for g-scale scenery. Basically it has horizontal slots about 1mm wide with 5mm between slots, about 3mm deep. 5mm is about 4 inches in the scales we work in, so if you think about all the thinks that are about 4 inches wide in real life, like bricks and planks, you can get some idea.
Picture above shows the raw material top left, at attempt at making decking or perhaps barrow crossing top right, brickwork bottom left (used a screwdriver blade to make the vertical slots) and clapperboard bottom right (used a craft knife to chamfer the top edge of each "plank"). With the brickwork and clapperboard I used fine polyfilla to lessen the depth of the slot, and with the brick I left a fine layer on top to represent the texture of bricks.
I just used felt tip pens for the colouring to get a quick impression. MDF absorbs water like a sponge, so for outdoor use you would need to varnish the end result.
