beavercreek
Back after a break and your project has progressed a pace Jerry. Some stonking work, it looks stunning.
That metal foil sure looks useful. I'll have to see if I can find some around here. Does it 'dent' if you have it glued over something solid and then bump it?Jerry Barnes said:Humpback boiler is 2 or 3 Pacific boiler tops spliced together. See page one, there they are covered with some thin plastic. You make it like a ships hull, make some bulkheads and glue over those.
I'll attach a detail shot of the dome that I used the thin metal duct tape on. You emboss it first, from the back for bolt heads, or lines that stick up. From the front for lines that go down. Then peel off the backing. This dome was flat on top, so I pressed down the embossed foil on top, made some cuts on the end(I had practiced with a scrap piece first). My idea was the cuts were metal welds.
Well, have you seen this topic....... ? http://www.gscalecentral.net/m130582Jerry Barnes said:I got the foil duct tape at my local hardware store. Has a backing you peel off it. If you put it over a solid surface, it won't dent, well if you ran your fingernail over it, pressing down, you would make a line, but you are careful with your models, aren't you?
Looks fantastic Jerry a job well doneJerry Barnes said:Here's a picture of 844 with the Centipede Tender I made for my Challenger build a few years back.
844DoneTender.JPG![]()
