Transformers
zman50
22 Feb 2019
164
4
68
Wisconsin
United-States
I would like to have one transformer to run two LGB engines on separate track. Is there such a beast out there? Thanks
Gizzy
36,138
2,273
63
Cambridgeshire
If you are thinking of something like the H&M Duette as used on smaller scales then the answer is no.
But if you have a DCC system like the Massoth 1200Z, you can run two trains from the one Navigator....
1,696
60
Do you mean transformer, or controller?
Homo Habilis
16 Apr 2016
49
7
58
USA
Assuming that I understand your requirements you could consider something like the Bridgewerks Magnum 200R though it might be a bit too much for your two LGB engines.
And as we say, "it's rather spendy", but it is a "beast"! :p
zman50
22 Feb 2019
164
4
68
Wisconsin
United-States
thanks for that link I checked it out and it looks really nice but price is up there.
1,696
60
I mean transformer with speed control on top of it. Thanks
I thought so, obviously you can get a transformer big enough to supply as many controllers as you want, but I'll leave the advice as to exactly what controllers to the real experience on the forum!
4,989
I would have thought an LGB 50110 and a couple of 52120 or older equivalents would fit the bill providing you are not trying to drive heavy amp pulling lumps of locomotives. You ought to be able to source all of these second hand in good working order for a reasonable price.
Eeyore.Boater
18
Stafford
United-Kingdom
Zman50 will probably need a 110/115 volt ac input version of the 50110, which is a 50111. The current version is a 60195.
Eeyore.Boater
18
Stafford
United-Kingdom
Low cost route would be a used laptop computer power supply/ charger. Available from most people’s junk drawer for very little money. Commonly available in 18 to 20 volts dc and about 5 amps (approx 100 watts).
Thanks D Dan it was 100 watts in my head, but must encountered some resistance before it reached my finger tips.
Alpineandy
499
Alpennines
I have used a universal laptop supply and train engineer for analogue running and never had a problem................
zman50
22 Feb 2019
164
4
68
Wisconsin
United-States
Low cost route would be a used laptop computer power supply/ charger. Available from from most people’s junk drawer for very little money. Commonly available in 18 to 20 volts dc and about 5 amps (approx 60 watts).
The laptop transformer is a interesting alternative, and 5 amps wow. Then I would just need some controllers. Thnks
Dan
28 Jan 2010
656
52
Eastern MA, USA
20 volts and 5 amps is 100 watts in my book. Althugh pricey, LGB has a 5 amp Hut and the controller for panel mounting can be found at times. Input for this hut is AC or DC.
3,521
100VA - Only equivalent to Watts for DC. - 'Lies to children(TM)'
But as we would say in a previous existence: "Good enough for television!" :):nerd::nod:
Rhinochugger
Retired Oik
4,240
North West Norfolk
I was once told that my father was volts, my mother was amps, so that's how they got little Watts :blush::blush::blush:
