I found a program to calculate the parameters on the big railways - and all your recommendations point in the right direction and can be re-applied for GScale. Here's an example, but I skiped all the formulas:
A shunting device with 2 axles / 250 mm wheel diameter / 4.000 kg mass has to move inside a production facility a wagon with 2 axles / 350 mm wheel diameter / 50.000 kg mass.
Questions to be answered
1. Can the shunting device move the wagon w/o slippage on dry track?
2. How many axles have to be driven to avoid slippage?
3. What is the max. acceleration w/o wheel slip?
Taken into account the specific train resistance and the friction steel/steel of 0,63 in dry state the results are
all 4 axles driven -> 0,165 m/sec² max. acceleration possible
just 2 axles driven -> 0,051 m/sec²
only 1 axle driven -> impossible to move / pull the wagon - just wheel slip
So what counts at the end is
> dry track & dry wheels for high friction coefficient
> as many driven axles as possible
> as much weight on the loco as possible
> reduce the train resistance (ball bearings, wide curves etc.)
Modern engines with just 82 tons weight try to avoid wheelslip to transfer a maximum of traction force. Sometimes this does not work properly...
The driver releases all brakes and rolls downhill at 2:55, finally the train starts moving forward at 05:30!
Andreas
