Some pics of my newly made traction poles and streetlights ( I may have mentioned elsewhere) anyway the pics speak a 1000 words, show the silicone molds to make the pole bases that are actually cast in resin onto the brass tube and the Pole Finials that are cast and glued on, note the wire in the casings of the finials, this serves 2 purposes, 1) it reinforces the object and hopefully will help maintainn the errr homogenous integrity ie stop is breaking and 2) fare easier to grab the wire and pull the resin casting out of the mold...
This is representative of the firts batch and I have changed the design slightly for the remainders.
I think they look ok and being soldered up from brass tube, etch primed and painted with epoxy enamel should last outdoors for a while... As can be seen I made a simple wooden jig to hold the bits to drill all the holes in alignment....
