The value you get will be less than the track voltage set on your DCC equipment..
But for test purposes, take a reading a few inches away from where you are feeding the DCC supply into the track. - But on the same length of rail, no joints between where you are feeding the track, and where you take the reading.
Then move further away from this point.. The reading should be broadly similar, though a little less.
If you find a point where there is a marked difference either side of a joint, then you probably need to open up that joint and clean the track-ends, before re-making it.
