Three into two?
Sarah Winfield
20 Jun 2016
1,080
231
79
Dorset
I'm just waiting for 4 LH R1 points to complete the track-work into my station.
Then I have to sort out the wiring!
SW
ebay mike
6 Dec 2011
4,082
717
Norfolk - edge of nowhere.
I electrocuted real frogs when I left my power on overnight once.... :eek:
I was hoping to buy a house in France and have another garden railway over there. It would have been nice to have the odd visiting enthusiast. Methinks I should cross you off the invite list - just in case!
3,526
Well, if the locals will walk all over the track! ;):eek::giggle::giggle:
1,700
Now, now don't be nasty to the wildlife
Gizzy
36,158
2,280
63
Cambridgeshire
Ah, but, I have French blood from my Mother's side of the family?
And Dutch from my Father's side.
Which probably makes me a Belgian....
ebay mike
6 Dec 2011
4,082
717
Which probably makes me a Belgium....
Next you'll be telling me you have a surfeit of 'zee leetle grey cells'.
1,700
Where do you keep it? In the fridge?
trammayo
4,687
Co. Mayo
Ireland
:eek::(
Due to the heat.. Having a jungle.. And possibly the cats and foxes??
I am in the unenviable position of being able to supply dead frogs..
:(:oops:
So they've actually croaked it?
Sarah Winfield
20 Jun 2016
1,080
231
79
Dorset
Back to the original topic.
My LH points arrived today and have temporarily been installed. The attached photograph shows how I have laid out my track to give me just what I envisaged. All trains in the station can arrive or depart from both lines leading out via the curves. It would of course be somewhat more compact had I installed a double slip (and might even have been less expensive!).
Without incurring too much of members wrath Where do I put my DPDT please?
If the worse comes to the worse I'll just use my Playmobil RC locomotives.
Thanks in advance.
Sarah Winfield
8 Mar 2014
7,806
972
San Diego
Armenia
www.elmassian.com
If I can make the assumption that the 3 tracks in the foreground do not connect to anything else, then you need insulators on both rails just past each of the switches from the mainline...
Sarah Winfield
20 Jun 2016
1,080
231
79
Dorset
You are correct in your assumption. So by putting in the insulated joiners as you say all of the station tracks will be isolated from the main line (my continuous run).
Please confirm the purpose of the DPDT switch. It is to maintain the correct polarity to the rails between the main line and the station?
Thanks,
SW
Gavin Sowry
2,490
70
Hutt Valley, NZ
Thanks,
SW
Yes.
Simply feed one end of the DPDT with wires from the left hand side of the insulated joint, and from the right hand side to the other end of the switch. Then use the feed out of the centre of the switch to power your sidings.
8 Mar 2014
7,806
972
San Diego
Armenia
www.elmassian.com
You have a "reversing loop", which means there are situations where the polarity of the tracks on either side of the insulators do not match.
So you power the "reversing loop" with a switch that can reverse the polarity AS NEEDED... of course I also suggested you add an LED so you can tell when you need to throw the switch.
You said you had this working before... if you have the switch set wrong, you will cause a short through the loco. Your DCC system SHOULD trip it's breaker in this situation.
Therefore you need to determine which switch position is needed to "match" which of the 2 switches you are traversing from the main to your "station".
p.s. it might be worth re-reading the extensive thread we did on this before.
Gavin Sowry
2,490
70
Hutt Valley, NZ
An effective way of knowing 'which way' to throw the switch, is to mount it on your panel so that it switches left and right, rather than up and down. If you want to go to or from your sidings via the left hand track, set the switch left, and vice versa. Worked for me for years. Greg's suggestion of LEDs is a worthy one, not too difficult.... but let's get the basic switch working first, the LED is an easy 'add
in' for later on. I've done just that on the Taita Gorge Railway. I'll dig out the page numbers for you to have a look at.
Edit. Check out posts 226 on p.12, and 261 on p14 of Taita Gorge Railway.
Sarah Winfield
20 Jun 2016
1,080
231
79
Dorset
This morning weather forecast gave a 30% chance of rain and the radar showed just a small indication which we have just had.
I am still hoping to at least install the insulating rail joiners and when it dries up I'll hopefully investigate the direction switch. (Switches and switch when they mean different things is confusing!)
SW
Sarah Winfield
20 Jun 2016
1,080
231
79
Dorset
So, I take the feed for power to my station through a DPDT switch from the main line. I install the switch in-line with the track so I will know which way round my main line the power will drive my locomotive? Sounds simple!
Greg, I'll consider the LED's once I understand.
SW
