Cliff George
jimmielx said:The loco as delivered has a small circuit board on the back of the motor
Yes
jimmielx said:and another one to which the motor and pickups are connected.
I don't beileve my Thomas had another circuit board, just the one on the back of the motor. I think later models were fitted with an NMRA reversing switch and may have been the cause of the extra circuit board. My 'James' did have two circuit boards one on the the motor and the second for the reversing switch and in that case I removed the reversing switch but retained the board with the interference surpression capacitors.
jimmielx said:I'd normally just bypass all onboard circuitry and connect the decoder directly to the pickups and motor, but looking at the pictures above it would seem that the board on the back of the motor has been retained while the other has been removed. Is that correct? I'd just like to check what has worked for everyone else.
As ntpntpntp says, you could take the board off of the motor, but for some reason I can't remember I decided to retain it (possibly I thought it was easier to solder too). I don't think it is causing any problem with slow speed running. If it had have done then I could have taken it off later.
