maxi-model
My prefered method - Colouron wood dye. Apply before any glueing or varnishing. Allow to dry properly before any further work. Sand the frets with fine grade flat block sander prior to any assembly or final finishing with varnish.
With overlays of different colours assemble and glue pre-stained parts before any varnishing. Any wood varnish will do, use 2-3 brush applied coats depending on how much of a grain textured finish you want. Make sure you let each coat dry properly before the next. Sand any surfaces, edges, butt joints, etc', that are to be glued together to remove any traces of varnish that is there so that it all holds together properly.
You could go to a combined wood varnish/stainer but that would not be so convenient where you wish to have different colours using overlays.
Here's one I made earlier with the above described methods
Suppliers - B&Q, Homebase, Etc'.
Max.
Just tidying the text up a bit
Max.
