What kind of superelevation you use?,
Not necesselerySuperelevation implies the use of speed. To my mind that is the antitheses of model railways. I suspect the majority of G Scale, and certainly all of 16mm scale, run narrow gauge models. Prototypically these ran at slow speeds. There is nothing worse, in my book, than seeing a model train being run at an unrealistic speed. For that reason I am not a big fan of live steam. Apart from the recent introduction of Slo-Mo fitted locos you rarely see live steam being run at realistic slow speeds which totally spoils the effect. If main line express trains are your thing, then by all means use superelevation.
Sometimes I can and sometimes I cantOn real railways they use the term Cant for this. If you google up Cant Angle you get this:
inclination from a vertical or horizontal plane; slope; slant. 2. a sudden movement that tilts or turns something. 3. the angle or tilt thus caused.
On course scale model railways like G scale, this should really not be necessary at most speeds, given the over-scale flanges used, but before WW2 Hornby 0 Gauge curves all came on sloping sleepers!
James
If you went down the Cant route, I would suggest a Coffee Stirer on the outside rail of a curve would give sufficient effect. Less is probably more with all that has been said on this matter.Thank you all for your opinions, I think I will have to reconsider the use . In my case it's gauge 1, marklin 1:32, I was interested in the visual aspect of the superelevation.
Jaime
Whilst light railways were fairly slow not all narrow gauge lines fell within their remit, particularly if they pre-dated the Light Railways act.
According to this source
https://www.festipedia.org.uk/wiki/Tyler's_Curve
This line's tightest mainline curve had a 3.5 inch cant on a two foot gauge!
I seem to recall reading that one went into the goods shed once, in error
The foreman hit the roofI hope the operator was slated for that.....
The Accy shay was the loco that first moved me toward this aspect of track laying - as it was not always enamoured with LGB R3 curves, but a little bit of superelevation, and she was as reliable as the rest![]()
