Suggestions for W&LLR style locos
B
Brummagem
3 Nov 2018
5
Birmingham, UK
Afternoon all,
Hopefully this is the right part of the forum to post.
I’m looking to start building a garden railway in the near future and wanted to loosely base it on the Welshpool & Llanfair Light Railway using Accucraft wagons and coaches for stock.
My issue however is around RTR motive power. I’m aware Accucraft produced an electric version of the W&LLR ‘countess’ however these seem to be rarer than hen’s teeth sadly and expensive (albeit i’m Sure worth every penny).
As such does anyone have any suggestions for a RTR steam loco I could use and ‘Anglicise’ (or its Welsh equivalent) that might pass muster? I was thinking of a re-paint, adding nameplates etc. I have an lGB ‘2091’ Class I plan to do similar with.
I’ll be using 45mm track if that helps and plan to use Remote Control as far as possible.
I’m definitely of the school that ‘if it looks ok I’m happy/not fussed overly with scale or prototype accuracy.
Thanks in advance.
G-force1
G-force1
Prevarication Rules!
4 Aug 2015
3,146
North Middle Earth
I too started out in that direction but have now diversified somewhat, for various reasons.
Part of your problem is that Accucraft seem to have moved on from supplying W&LLR stuff. That has caused the prices of S/H stuff to stabilise at the higher end. There weren't all that many electric variants of the locos anyway, mostly Live Steam.
The Baguley Drewery (Chattenden) is still available and is fairly easily converted to battery power and R/C if you so desire. Other than that I think all that is left is a No 14 as Live Steam, and then whatever you can find S/H.
Reactions: Brummagem
276
71
You could think about an LGB U2, whilst they never had one the Austrian 0-8-0 that they have is on similar lines. One of the LGB U2’s should be a relatively easy conversion to Battery Ppwer if that is your thing. Plus a second hand good working example will not break the Bank.
maxi-model
maxi-model
131
Bucks/Oxon/Northants area
UK outline NG seems to be very much the preserve of live steam operators in a scale that will look right on 45 mm gauge track. You could look to Garden Railway Specialist's range of kit built track powered UK steam outline NG locos. A bit of modification of even scratch building onto one of their chassis might do the trick. How much is your budget per loco and do you intend to go DC, DCC or Battery with manual or r/c operation ? Max
Rhinochugger
Rhinochugger
Retired Oik
390
North West Norfolk
Yep, my mind was wandering that way - could be converted to an 0-8-0, come to think of it, didn't James Hilton do something like that?
R
RogerK
3 Jun 2018
42
1
USA
How about the LGB 20781 MTVS cl 030T Corpet - Louvet Steam Locomotive? I know it is French, but to my ill informed American eyes it looks fairly British to me.
I am also interested for similar reasons. I run Accucraft W&L rolling stock behind a Roundhouse Silver Lady, but would like a battery powered RC option on my deadrail layout. No idea how difficult this would be to rewire. Available in the US for $630. Website is onlytrains.com
Also a couple of preowned older versions (LGB 2078) for $550. Would these be easier to rewire without the MTC ready interface?
Rhinochugger
Rhinochugger
Retired Oik
390
North West Norfolk
Mmm, I also thought of a carpet hoover, particularly as there was a Cambrai for sale on evilbay. I mean, although it didn't grace W&L metals, it's stored not far away :think::think::think:
G-force1
G-force1
4 Aug 2015
3,146
North Middle Earth
Does anyone make a Resita?
You'd need to have two, then refurb the worst one and strip the best one apart, and flog off all the best bits. Just like they did with the one we gave them!:banghead::banghead::mad::mad::mad::mad::mad:
Rhinochugger
Rhinochugger
Retired Oik
390
North West Norfolk
How close is that, proportionally, to the Rugens 0-8-0?
P
Paradise
28 Jan 2010
611
51
276
71
I have in mind a job to convert at least one of my Corpets to Battery Power. Having been in side one it would not be a massive problem. After all if you look at some of my Battery Conversions, Corpet is a relatively larger loco. As for being W&L, well wrong Gauge, wrong Country etc but rule 1 can apply.
penylanpip
penylanpip
1 Apr 2010
220
10
71
Barry, UK
I purchased a somewhat damaged Corpet and gave it the treatment I believe Greg envisages in his original post...
and with her unmolested sister...
I don't model any particular theme now (did that for 20 years in '0' gauge) and just wanted something a little less continental to run with some UK rolling stock. There were, after all, some unusual beasts operating on Britain's narrow gauge in its day.
Reactions: Rhinochugger
Rhinochugger
Rhinochugger
Retired Oik
390
North West Norfolk
Cambrai operated in England - somewhere north of Watford :emo::emo:
G-force1
G-force1
4 Aug 2015
3,146
North Middle Earth
P
Paradise
28 Jan 2010
611
51
Here is a reference photo for size difference of the 1:19 Accucraft Countess and the LGB 1:22.5 Corpet Louvet, also borrowed from the link in my previous post.
Rhinochugger
Rhinochugger
Retired Oik
390
North West Norfolk
Mmm could be an issue with coaching stock - or could 'big up' the cab :think::think::think:
P
Paradise
28 Jan 2010
611
51
Perspective in that photo is not helping matters. The Countess does have a fairly big looking cab which roughly matches the height of coaches on the prototype so I suspect the same on the Accucraft models.
Unless that is Bilbo Baggins on the throttle. :giggle:
Welcome | Welshpool & Llanfair Light Railway
Rhinochugger
Rhinochugger
Retired Oik
390
North West Norfolk
Nice piccy to cheer up the day :):):):) you can even forgive the GWR livery :D:D and yes, as I thought, the coach roofs are similar to cab height, thus a 'Cambrai' would need a bit of adaption. It might not be so obvious with a mixture of goods stock :shake::shake::nod::nod:
