Here are the results.
The main things I have done are;
1) Dismantle.
2) Remove the rear lamp and power supply plug
3) With tepedation cut an opening in the rear cab of the Stainz.
4) Cut of the rear single buffer and housing.
5) Some plastic surgery to the rear coupling to close the gap between the loco and tender.
6) Connection between tender and loco to in effect provide a common bus between all pickups.
Here are the results. I think it looks OK. Whats your view. Now to weather or not to weather and if so how do I do it?
Also the chuff sound has gone off since I wired the common bus but all the lighting works. Any thoughts.
Mike
