tramcar trev
So everyone has tried making smoke?
Did you hear I'm gathering bits to build a battery powered steam tram? So, it will have a Li Po battery inside its little fake boiler and I'm going to try and make smoke appear from the funnel.... To this end I have to design and make my own smoke generator as the commercial ones are expensive and don't work that well. So I propose to make up a short cylinder from copper tube and a solder on some flat ends with a small length of 10mm brass tube ( that pokes into the funnel)out of the side. Inside will be a small length of Ni-Chrome wrapped around a piece of fibreglass rope the ends of which will sit in proprietary smoke fluid dropped in through the brass tube........ On one end of the cylinder will be a 25mm fan that draws.......08amps (80mA?). To get the "chuffing effect" I think if the fan could be pulsed on and off while the element stays on a realistic effect could be got. I'm thinking a simple led flasher using a 555 would work to switch the fan on and off, the circuit in the picture is using 9v I will have 11.1 and 6.8ah from the Li Po battery do you think the 555 could handle the 11.1V.? the rate of "flash" is controlled by the resistor values..... I did think a cam on an axle switching a micro switch on and off would work to but then space is off the essence . Thoughts? Opinions? Been there tried that?
