I have put a TCS-T1 decoder in my Bachmann Thomas. This is the first decoder install I've ever done (apart from plugging in decoders to LGB's "direct decoder" sockets) and I was pleasantly surprised with how smoothly it went. Unfortunately I now have a HST (High Speed Thomas) on my hands, and need to put the brakes on it a bit, otherwise the kids will have great fun sending him full speed round corners and flying off the track!
The only means of programming the decoders I have is my LGB universal remote (serial). I know this isn't ideal, but I have successfully used it to program the loco number of Thomas, and set CV29 to 5 (14 speed steps, plus reverse direction).
To program the loco number, at the P -- display on the remote, I did 1 6 > then Thomas moved slightly to indicate that the programming had happened.
To program CV29, I followed what the manual told me to - 6 29 > (move) 5 5 > (move), and that worked fine. So far, so good, Thomas now goes in the right direction and has the right loco number.
Now, the documentation for the T1 decoder seems to say that the easiest way of slowing Thomas down will be to set CV2, CV6 and CV5 for the low/mid/high speed respectively, using a value between 0 and 255. However, every method I have tried of setting these CVs hasn't worked. I've tried setting them directly (in the same style as setting the loco number, as somewhere I found on Google said that it was possible to set CVs 1-6 using the serial system directly) and via the CV6 (select CV) and CV5 (value for that CV) method.
Most of the time, when I've tried setting these CVs, I've ended up rendering Thomas immobile, thus requiring me to do a factory reset via 6 8 > (move) 5 2 > (move) which fortunately works fine!
Where am I going wrong? Help!
Should I be asking for something better to program my decoders for Christmas?
