A left hand point would possibly have worked better leading to the Crossover. You may have needed some odd short sections to get things to match up but sure it would all flow smoother.Just a quick update with some snaps for now, bought a few more points and some buffer stops. Finished the loop. Ran a loco round light engine to see that it wasn't going to do a barrel roll, few bits I need to work on but yea.
Buffer stops
Started playing with yard layout. I wanted to use the crossover but I think in hindsight this is just a bit messy and silly, plus the wagons don't like it all. The bogies can't cope with the constant direction changes over track that isn't 'just track' and derail too much.
View attachment 254971View attachment 254969View attachment 254968
It looks fun though..
View attachment 254967View attachment 254966View attachment 254965View attachment 254964
Pulled a train around for a bit to see how the line would do with stock
I did take some video but I need to find time to splice it together a bit. More soon!
Must be a terminology difference... here in the US a crossover is the switches that connect 2 parallel tracks, those closest to you in the picture.
A crossing is normally called a "diamond" in the trade, to keep it from being confused with a road crossing the rails. A diamond can be seen on the right track just past the crossover.
So, in the UK crossover = US diamond.... if so, what is the track configuration called a "crossover" in the US?
(pardon the pneumatic hoses on the track)
I was referring to everyone calling something a crossover and I cannot figure what picture he is talking about... I'm guessing it's the small "yard" with a diamond crossing in it...
But want to learn the UK terminology...
I can't help but think that crossover will end in tears...
It severely limits the amount of stock you can get, in both roads...
You WILL get more stock. I promise you!![]()
ALWAYS...............
Make sidings, and passing loops, as long as possible.
I think that was a "double crossover" just to really confuse things, having 2 crossovers at the same place also requires a diamond crossing:
Also known as a "scissors" crossover, for obvious reasonsI think that was a "double crossover" just to really confuse things, having 2 crossovers at the same place also requires a diamond crossing:
