GNB
I recently constructed some simple lineside structures/buildings using an inexpensive (£2.50) plastic weather proof endtile available from B&Q.
Here`s some images of the structures.
This small maintainance depot is the simplest and was constructed using one endtile attached to a small piece of decking plank with a support hidden at the back. The short mounting piece has two holes drilled into it to match the `pegs` seen at the intersections of the ribs. It held in place with rapid setting Evostick wood glue applied to the pegs and the section of the ribs in contact with the wood.
The structure of the underside of the tile together with the construction detail of the timber support attached to the underside of the tile is shown in this image. You can see on the tile undersurface, at the base of the image, the four large rectangular clips. These allow you to link the tiles together to form large relatively stiff structures.
An example of a larger structure is shown here as what could be described as a large station canopy. The rigidity of the tiles allows three pairs of tiles, each pair attached together by their clips, with each pair bolted together on their opposite axis. For this group of six tiles there is only one central support that is simply attached to the tiles using the stiff cross ribs on the underside of the tiles.
Detail of the construction of central support is shown in this image. It`s constructed from timber decking off-cuts, screwed together with attachment slots cut into the top to locate onto the ribs on the undersurface of the tiles.
The weight of the base is sufficient to locate the structure without problems. The clearance height was 10`.
Its not difficult to see other possibilties for this inexpensive material.
Have fun
PS - The tiles were labelled composite paving tile edge, size 40x20x4.5 cm. Their B&Q stock number is 5052931491230. The underside of the six linked tiles is shown on the attachment.
Have fun
