Signal box levers
vasim
3 Jan 2010
540
flyingsignalman
Narrow Gauge railways, Garden railways, Signalling
1
Wirral
vasim said:
All mainline signalboxes are "locked by the block". The exceptions being Intermediate Block Sections (IBS), Permissive Block Sections and No Block Sections. Groundframes are completely different and don't form part of a block. In any case, the white band would add more interest to the model.
Not quite, where there is an Intemediate block section (IBS) the starting signal protecting the entrance to the IBS wouldn't be realeased by the block but the IBS signal protecting the entrance to the Absolute block section would.
It is only in the last 20 years or so that all signals became locked by the block; Ellesmere Port No2's up starter was "free" until the box closed in 1983 and at Bromborough, until it too closed (in 1985), the down starter needed a line clear but when you had one you could pull the lever off as many times as you liked.
LNERGE
1 Nov 2009
189
3
There are still a few boxes, and i think two are in our capital city, that have starters not locked by the block.
PaulRhB
This Way Up
408
Wilts Drifting toward the RhB,plate tectonics rock
vasim said:
Whilst pulling a signal off slowly is not in the method of working, a driver knows what the signaller means. You can't do that with an electric signal anyway, semaphore or colour light.
The rule book says to only clear the signal when the train is at, or nearly at, a stand at the signal. With colour lights you use the nearly at a stand to keep them rolling while they used the slowly pulling off with semaphores as a message to the driver that it was caution rather than I forgot you. The nearly at a stand still applied with the semaphore. The semaphore just allows a bit more communication to the driver.
We sometimes stop freights using the diversionary loop at Laverstock on the slight downgrade on a red to allow the train in the section ahead to get to the top of the bank. Starting the train off on a yellow means he trundles round the loop and gets a rolling start at the bank on the other side rather than getting stopped again at the bottom of the bank. Word of mouth between the drivers lets them know what we are doing and prevents working the loco so hard up the bank from a standing start. It does make a huge difference to the speed up the bank starting at 20 rather than 0.
