Parkdesigner
So while I wait to get the last pieces to finish the P10153, I figured I would start in on the second car in the consist.
I have long wanted one of these type cars, though the only ones I knew of were the rather expensive Magnus units, or the kit built versions from Stefan Wyss (also not cheap).
When LGB announced their new 34553 RhB baggage van, I thought “great!” however the first reviews of the car from the pre-production models came in and I quickly lost interest. (For those that don’t know, LGB modeled the wrong frame, the wrong axle distance, the wrong tool box placement, the wrong wall height, the wrong roof profile, the wrong sliding direction for the door, the wrong…. well… let’s just say the pre-production model was a... poor imitation of the prototype.)
Then the actual production version started to ship and the door slides had been fixed... and that was about it.
So I continued to ignore the car, but something just wouldn’t let me stop. As I proceeded with the P10153 build, I found that the Xbk 9089 actually ran alongside this car and so now I was determined to figure out how to build one.
Step one: order the car.
Step two: change this:
Into this:
I decided to begin with the frame. I’ve had a D4062 lying around for a while now, so after consulting the Schweers + Wall plan book, it graciously “donated” its frame to the build! I stripped the 34553 down and did the same to the donor. Next I drilled out the body’s mounting posts to its original frame, allowing it to flush mount to the new one. The other major bit of surgery was removing the lower baggage door guides. These were molded on to the frame of the D4062, but the car body of the newer model had the guides installed as a separate piece.
I also disassembled and began to modify the end platforms off the 34553 so as to make them mount to the new frame ends. One interesting note is that the frames are about 3 mm shorter on the new car, so I will have to shim the ends to match the railings. (Not a real problem, as the faux wood flooring will cover this.)
Next up is:
The big question is whether or not to tackle changing the roof profile. I’m still having a think and exploring options for a replacement roof. If I can find one that is more or less “drop in” then I will have at it - but if I have to scratch up my own roof, I may call it quits and leave the current one in place.
As you can see, this is just getting started, and will take time as I hope to turn this weekend’s attention back to the P10153 and getting it finished.
But overall, even just shifting the frames - I think that the below pictures really justify the effort as the axle spacing already looks much better under the car body.
Cheers,
Josh
Into this:
Next up is:
- Getting the end platforms finished (harvesting parts from the original model and shimming into place on the new frame)
- Repositioning and fitting one of the two original battery boxes
- Cleaning up the flash on the frame itself
- Modifying the side door steps to more closely resemble the prototype
- Adding a few bits of detail here and there (including new body-end railings)
Cheers,
Josh
