Hi all, hopefully someone can help with this - one of the locos I've just sold on the forum, the LGB RhB "flatiron" electric, went to Les (Dinas Bryn) - it was all working fine last time I ran it, but Les is having some problems getting the lights and sound to work. The loco is factory-fitted with MTS (presumably a standard LGB onboard loco decoder, though I never looked inside), and the chap I bought it from had fitted it with an LGB "black box" sound module. While I had it, I never ran the loco for more than a couple of test laps of a temporary track, but when I did that everything worked perfectly under MTS 2 (parallel) control.
This is what Les wrote to me today (quoted with his permission):
"my is MTS2 paralled, if the flat iron is NOT I put in something is it 9/2, I know when Paul came over he put in something on another loco. What is happening is
1 putting power to track the sound starts up(like the diesel) then closes down as prototyte when not in use, but when the loco is needed I get no sound, on steamers I press 8 to turn sound on or off, I can't get sound unless I turn mains off, I don't like just pressing numbers,
2 with all my LGB locos I press 9 for light on or off
The loco works fine, any ideas ? Les"
Anyone got any ideas why Les is having this trouble? His control setup appears to be exactly the same as the one I ran the loco with. Hopefully Les will be reading this tomorrow and will be able to answer any other questions about what he's tried - I'm stumped, because I thought everything was working fine.
Thanks in advance for any advice!
