Greg Elmassian
Guest
After all that, you would figure that the 10 minutes of cutting would have been completed!
Probably gotta buy 'em firstPerhaps plucking up courage to take the saw to an expensive bit of track??![]()
Looking at mine which have an 8cm spacing between the tracks at the closest rails, the cut has been between the 2nd and third so if you are wrong you still have some latitude to adjust. However my suggestion would be to cut in the middle of the first sleeper after removing it, that way you can gauge what you have achieved without fatally trashing the point. Ok so you may have to cut 2 or 3 times to get where you need to be, but a much safer route.Ok, so I’ve taken the old points out and made a start on laying out the new ones.
I still need a left hander, and the curve to join the heel of said left hander to the heel of the king point (no.1 in the photograph). I should be able to get hold of these tomorrow.
Now, after laying everything out I reckon I need to cut the rails half way between the first and second sleepers.
For those that have done this Mod already, does that sound about right?
I’ll be able to fine tune it all once I get the remaining track tomorrow, but just wanted to see if I was on the right lines, if you’ll pardon the pun!
Actually with Long Massoth Clamps you could repair a few MM Overcut at a cost.remember, you can always cut more, not less
cut a little long, fit up and cut some more... use a dremel cutoff wheel if you have it.. fast and easy, so you won't mind doing it a bit at a time
See we told you it was! Don’t you just hate smart a r’s. My excuse, well I do have a Smart car which is Trams when spelt backwards!My word it almost looks doable! View attachment 250904
whatever you are thinking on the rightmost piece of loose track, if the position shown is your plan, please rethink!
I think you are right, just being overly cautious...![]()
Have to disagree no such thing as a "nice" reverse-curveA 'nice'reverse-curve, just there, would be a great way to throw stock onto the floor!
Yebbut nobutt, if using set track - then yes, you're right.Have to disagree no such thing as a "nice" reverse-curve![]()
