Yes, I've had a play with it. Mechanically (electronically) it works well, ergonomically its not that flash. Ergonomics are great in the original case for flying but I guess none of the other model train controls are ergonomic either ( and I put it to you that ergonomics are not a consideration in those either). I'm going to work on it, the case needs to be slimmer and thinner. If I used 3 LIPO cells to power it I could make things a lot smaller. But I can control 3 trams with it easily at the same time if they are following each other, it gets tricky when one is on single track approaching another with a passing loop between them. Kinda like touch typing; if I sit it on something and watch the trams rather than the controller and memorise what knob controls what tram then it overcomes the ergonomic problems. For a large railway it would be the antz pantz if you can set a few trains running and can rely on spring loaded points to avoid, as the Americans call them, "Corn Field meetings".
Overall and for my purposes I give it an 8/10, it would get a perfect score in a smaller case with each knob within a finger/thumb reach.....
