tramcar trev
I want to do this with my 6 Channel Hobby King transmitter. I'll put it in a new plastic box with 5 knobs for speed control and one switch to turn smoke on and off. This allows for 1 knob for each of 5 trams which as I have discussed before will have manual reversing and auto directional headlights...
Problem; the potentiometers are 5K ohm linear ( that's what it says on the pots B5K0) but only the centre 60 degrees of the 300 degrees of "turn" are used and I want to replace the pots and be able to use the full sweep of 300 degrees.
Solution; As the pots are 5K over 300 degrees then divide the 5000 by 300 = 16.6 Ohms/degree of rotation. Ok so then as I have 60 degrees actually used there are 996 ohms in the swept area using the existing joystick. So if I use a 1K0 pot with a 2k0 fixed resistor on each "end" I end up close enough to 5K0 overall and the pot can be used for its full travel.
Can it be this simple? What am I missing here? If it is this easy then the only tricky bit will be desoldering and resoldering the coax for the antenna....
