Refurbishing LGB Point Motor Connectors
Ralphmp
6 Jan 2010
1,640
228
72
Herts
England
Yesterday I was temporarily lifting track to carry out some maintenance and, out of the 5 LGB points I had to move, the screws holding the cables from the decoders into the point motors had rusted solid in 4 of them. (I'm sure it won't come as a surprise to many of you that the "rust-free" set are somewhat older than the others...)
Despite soaking with WD40 I have been unable to free the connector screws.
Having opened up one of the motors it seems relatively easy in principle to replace the connector block. I just wondered if anyone else has done this and, if so, did you find/use a direct replacement part? If not, can you remember / share where you found a suitable alternative from.
Thanks.
Gizzy
36,152
2,278
63
Cambridgeshire
I have unsoldered the connector block and wired in a flying lead to connect to another motor, where ever I use motors on paired crossovers.
Not actually found a replacement though Phil....
Ralphmp
6 Jan 2010
1,640
228
72
Herts
England
Funnily enough I've been thinking along similar lines as this would allow me to connect the flying lead to the wire from the switch decoder somewhere "under cover".
Did you use any sealant or similar around the wires where they exited the point motor?
Gizzy
36,152
2,278
63
Cambridgeshire
Yes I did use sealant around the holes Phil. An aircraft grade black mastic that we use on avionic kit at work.
Does the job....
D
Deleted member 1986
Guest
Edit:
Reactions: 2 users
Ralphmp
6 Jan 2010
1,640
228
72
Herts
England
Thanks for this - much appreciated
stockers
3,795
65
Nr. Ashford, Kent. England.
James Day
Guano Corner Rly - Runs weekly - Guano permitting
6 May 2012
1,726
349
Warwickshire
Excellent - thanks
An interesting thread, as I have just lifted my own line (for rebuilding) and am working through cleaning and servicing my recovered EPLs right now. Only two had rusted/seized terminals, but when dismantled these both turned out to be the most recent ones, with the thin geared rotor, reinforced base as the modified rack bar,
None of my earlier 80s, 90s or even early 2000s type suffered from this, although they had all been out there in similar conditions for the same time.
The same is true of the modern type of add-on switches too, only the most recent ones have srews that seized up.
Have LGB changed the material?
James
4,997
James
Long will me mourn the quality of products from the Richter days of LGB.
James Day
6 May 2012
1,726
349
Warwickshire
Pity Really, as Marklin are no slip-shod organisation and come with a very long history of well engineered robust models, but as we seem to agree, they seemed to have spoiled the ship for the want of a very small amount of tar.
Have to confess that I don't like the new type of screws. The simple straight slotted type were by far the best and seemed to be made out of much better material, but there we have it!
3,525
This is probably more a case of what they can get these days..
Materials, and perceived wisdom, change over time..
Bit like cars.. Mine id an old German-engineered 'tank'.. Will never get another one where the components (and car) are built to last.. If it has built-in obsolescence, then you can sell the punter another one!
