Yes, once when visiting a layout with R5 points? My V52 had the problem one one side of one of the bogies.
Check the springs in the skates. Also check that the skates are free to move/bounce and if needs must, bend them in a little until the problem is resolved....
Problems with LGB R5s? No - I run all sorts of wheelbases through them - IVKs, Mallets, RhB 4/4 Is, IIs, IIIs, Crocs, Ruegen 0-8-0s, and a variety of different makes - KISS, LGB, BRAWA - etc etc and never a hint of any problem. It may be that some of the skates on your traction are slightly out of line - that happens quite easily; another possibility is that the points themselves are twisted or not laid flat enough in some way, but given the LGB elephant test that doesn't seem likely.
