pugwash said:
Apparently Piko are "about" to release a R3 double slip, but I think Gizzy would suggest you don't hold your breath. There again if you aren't in a burning hurry it could be worth waiting for.
Funnily enough I have just received an e-mail from PIKO to say that they will not be making the G-DKW R1 double slip that they originally advertised here;
http://www.gaugemaster.com/piko/Piko-G-Scale-Track.pdf
New brochures do not now show this.
There is a lot of confusing issues with the LGB double slip geometry? It is roughly R2, but the important thing to remember is the arc angle of 22.5 degrees, which is the same as the R3 points. In a crossover configuration, you have to use the small LGB 11040 short straight track pieces to get the correct track centres of 185 mm.
To use with R1 points or the LGB 12360 3 Way Point, which have an arc angle of 30 degrees, you need to use the LGB 11152 short curve of 7.5 degrees arc.
LGB Track Geometry can be found here....
http://mediencms.maerklin.de/media.php/de/produkte/sondereditionen/lgb-tracksystem-160_large.jpg
