R/C Not working
Hekate
21 Apr 2017
42
10
Normandy
The next problem I have is that the DIMAX Navigator does not work in R/C mode. Tethered it works fine. The red light is on the Receiver but the Navigator shows a black cross through the loco picture on the screen. It worked fine the last time I used it. Any ideas ?
Gizzy
36,175
2,288
63
Cambridgeshire
Have you tried resetting or repowering both Navigator and Z1200....
Hekate
21 Apr 2017
42
10
Normandy
I have turned them on/off multiple times, tried a new cable. Replaced batteries in handset, cleaned contacts in receiver, Can`t think of anything else !
stockers
3,795
66
Nr. Ashford, Kent. England.
Check the radio is fitted tight and check the receiver module. Is the ariel inserted?
Hekate
21 Apr 2017
42
10
Normandy
I have cleaned up the end of the aerial, also the socket it goes into, still not working. It could be a fault with the receiver but at £100 a time I don't want to buy another one on the off chance.
Neil Robinson
579
N W Leicestershire
I wonder if changing the radio transmitter channel would have any effect.
Ralphmp
6 Jan 2010
1,640
228
72
Herts
England
Does the Navigator display show there is a link with the central station? (There should be a picture of an antenna in the top right corner next to the battery symbol)
If you don't have this, it's worth confirming that the Navigator RC channel matches that of the wireless receiver as described in section 8.9 of the Navigator manual (downloadable from the Massoth Wiki).
If you do, then try editing an existing loco config or creating a new one, and then see if you can connect to a loco. I have had the "black X" on a couple of occasions and when the usual power off/on didn't work, the create/edit did the trick.
stockers
3,795
66
Good suggestions Phil. Why didn't i say that!
Ralphmp
6 Jan 2010
1,640
228
72
Herts
England
Just coincidence! I've been looking at R/C channels recently as I'm trying to work out if I need to make any changes to have 2 Navs and a Feedback module connected wirelessly to my central station.
D
Deleted member 1986
Guest
Navigator Transmitter and the Receiver are set to TWO different RC Channels ?......
stockers
3,795
66
All on the same channel.
D
Deleted member 1986
Guest
As well as all being on the same RC Channel, each wireless device requires a separate individual ID.
Tanker man
G scale and 5 inch ride on
10 Jun 2015
750
267
Oxford
I had this happen to me on my last open day two years ago, everything had been working fine then it just stopped. My receiver is under a 2 Ltr bottle cover on the stub branch of a tree, to give me the widest coverage of signal, on inspection, I found a family of Earwigs had moved into the blue box! Nothing I could do, after evicting said tenants, would make the receiver work. It went back to Massoth via 'Muns' , and the repair cost me £14 . It now works fine again, but I have sealed it inside the cover now. There was no explanation from Massoth as to what the problem was. It was a little annoying being away for several months but better than £100 for a new one, and I could still use the railway with the handsets tethered.
Dave
