Wistow vale rlwy
I changed the address of my Nicki and Frank S (LGB 24266) from the factory-default of 3 to 10. A simple enough procedure (I thought!) but all is not well! Using my remote handset (55015p) and the programming module on a dedicated programming track I carried-out the following:
C _ showing on the hand controller, 01 entered for address CV.
d _ now showing on controller, 10 entered and right direction button pressed to confirm.
Audiable 'click' heard at loco (as has been usual in the past) and C _ again now showing on hand controller.
Powered-down and loco put on railway.
Power applied, loco address 10 selected, loco movement ok, sounds ok but no lighting, front, rear or cab.
Trying button 9 on remote handset (toggle lights on/off) has no effect on lights BUT pressing this button whilst loco is moving has the effect of toggling the speed between low speed and normal speed.
One of the controllable functions of this loco as detailed in the booklet supplied with the model is 'Low speed switching range and Double A switching light' this function is available by pressing 15.
Thinking that maybe the mapping had screwed-up in some way I tried 15 to see if it effected the lights in any way - I got a long locomotive whistle (1) and a short whistle blast (5) together!
OK, lets start again. In the booklet CV 8 is a reset (to defaults I thought) So, back on the programming track I set CV 8 to 8, as detailed in the booklet.
Back out on the line some sort of reset had taken place as the loco had reverted to address 3, but the lighting issue remains and button 9 continues to toggle speed between low and normal running.
Does anyone have any ideas on where I have gone wrong please?
*The loco performed normaly before I attempted to change the address.
(and what is 'Double A switching light?) ???
