kim
retired at last
I bought this a while ago from Darren at Top Slots for very little money because it stutters when setting off with front and back lights flashing and then stops for no apparent reason. On taking the bottom gearbox cover off the loco I found 2 teeth missing from the cog on the front driver axle and the same on the intermediate gear, replacements ordered. Appreciating that the flashing lights suggests a dcc problem I thought I'd see what fixing the drive brought about. Anyway, new bits duly arrived and fitted today, well lubed and loco put together again, guess what, still stutters!
Altered the speed steps and found that on 128 steps and given full throttle the loco moves off - a bit sharpish - but with no stutter and then runs perfectly in both forward and reverse, front and back lights flash a couple of times and then behave. The loco will slow down to a crawl and behave but once stopped it needs to be off at full speed.
Thoughts please.
Thoughts please.
