Greg Elmassian
Guest
Phil P: raising it will give a little airflow to the OUTSIDE of the bottom, will not significantly cool the interior since plastic is not a great conductor of heat.
Putting on a sheet of white paper would reduce the heating of the PAPER, if it was in the sunlight. But since the box is opaque, no sunlight under the box, and since wood is a good insulator, the part of the wood in the sunlight will not conduct "sideways" to the underside of the box.
I completely agree with Neil in the first and second steps he outlines, those were indeed my next suggestions. It is possible that the overtemp/overload circuitry is shutting off too soon, but personally I doubt it, BUT swap it out first, it could be true.
Personally, I would most likely find a way to actually have a small fan inside and a screened hole in the bottom, as heat ages solid state components also.
