idlemarvel
Neither idle nor a marvel
I guess many readers have a signal box on their layout. I just acquired and built the above mentioned PIKO kit. I have to say I am very impressed. I have been building plastic models of various kinds for around 50 years and for the quality of mouldings, design, finish this would be hard to beat. The end result is quite impressive out of the box (no painting required). It's a bit of a monster compared to the Airfix kits of my youth! The box is 600mm x 400mm x 100mm and must weigh best part of 2 kilos. I had great pleasure putting it together. The instructions are very clear. My only advice would be to look out for the two door handles when you open the box before you throw away the wrapping; they were detached from the sprue (in order to be hand painted I guess) and where hidden in some scrunched up paper inside the box. Also note that the 4 short concrete wall sections are not the same, make sure you dry fit before gluing. I made the bespoke signage by scanning in the supplied signage sheet, edited it with MS Paint and substituting my station name. I used MS Gothic font which seem the nearest equivalent, printed that and laminated it. Doubtless somewhere there is an official DB font but if you apply the "one metre" rule you couldn't tell.
