Has anyone had experience with the Piko switch motors? I'd like to hear some of your opinions, good or bad.
Madman said:Has anyone had experience with the Piko switch motors? I'd like to hear some of your opinions, good or bad.
Yes, they can directly replace EPL motors.Madman said:I was thinking about the size of the motor. Are they direct replacements for EPL switch motors? Would there be any problems with interference from locos or rolling stock? Do they operate on the EPL system?
Gizzy said:Yes, they can directly replace EPL motors.Madman said:I was thinking about the size of the motor. Are they direct replacements for EPL switch motors? Would there be any problems with interference from locos or rolling stock? Do they operate on the EPL system?
No issues with interference AFAIK.
They work fine from an EPL system or an LGB/Massoth Point Decoder....
I am trying to find out , by diagram , or utube or what ever works, how to hook up the piko switch motor. I have three of them and am trying to get power to one of them to work{•~•}.Significantly larger in size than the LGB, but much better waterproofing (which accounts for some of the extra size). In terms of operation, no different to LGB's. Too early to say whether they will last as long as some of my LGB motors (14 years for the longest-lived!), but no obvious issues so far.
If they are taller than the latest EPL drives interference may be an issue. Check carefully if you can before committing to buy. I had some of the first edition EPL drives with the slide on top that could be used to manually throw the turnout. The slide interfered with the rail clearance devices (some call them plows) on my LGB 20273, G3/4 Rhatia. This only happened when the switch motor was thrown toward the rails. It took me a while to figure out what was going on. I had to remove the slides which was easily done. I then covered the resulting hole with mastic electrical tape to keep water out. I assume there would be a similar issue with all the LGB RhB G3/4 variants and the early EPL drives.Would there be any problems with interference from locos or rolling stock?
