I dropped by the Kent G Scale Society meet at Teynham today, and whilst admiring one of the layouts the topic of conversation turned to the Peco points and the problems with skates shorting on the point frogs (the layout was running under Massoth DCC).
Some time ago on the old G Scale Mad site I wrote up how I converted some Peco points to live frog. I've found the original photos and notes so thought I'd copy and paste them back up as a thread here in case anyone finds it useful.
It's not the only solutution to the shorting skate problem of course.
There is the simpler/cheaper (and perhaps more temporary) method of painting the frog tip area with varnish, but I felt that would increase the dead-spot.
Other folk have gone for a "half-n-half solution" where they've used a polarity changing switch, modified the wiring to bind the existing frog rails together and to the polarity switch, and used isolating fishplates. That works quite well.
Anyway, here's what I did...
Having used live frog pointwork in N scale for many years, I thought I might as well have a go at converting one of these Peco points to have a live frog, and thus remove the problem of shorting skates. I reasoned I might also be able to reduce the ?dead spot? at the frog, for the benefit of small locos.
[/font]
So, two issues to resolve:[/size]
1) Rebuild the frog with metal rail, with the minimum of alteration.
2)[/font] Provide a means of switching the frog polarity when the point is thrown.
Task 1) rebuild the frog:
To rebuild the frog with metal, might as well use the existing frog rails as they?re already ground to the correct angle where they enter the plastic frog unit. First turn the point upside down and remove wire links bridging the rails underneath beyond the frog. I used a Dremel type tool to grind off and clean up the underside of the rail where the wire links were spot-welded. This will allow the frog rails to slide out from the chairs.
Remove the star washers holding the plastic frog unit in place.
(in the photo I?ve already done these operations)
Slide out the two frog rails. Remove the plastic frog unit. Carefully cut out and remove the entire ?tip? section of the frog.
The tip of the frog rail from the ?straight? side of the point will be the tip of the new frog. Grind about 15-20mm off the foot of the rail next to where it?s already ground to an angle. This is to allow the other frog rail to butt up properly.
[/font]
