Rhinochugger
Retired Oik
Trust me, as a professional wordsmith, I amI had thought this was 'only' when using online editor's? - But you may be correct?
It is a right-royal PITA!
Correct, that is, not the other - well, most of the time
Thank you for that. Hopefully those that were having problems will be OK now.Maximum image size has now been increased.
Paul
Hi, is this size in bytes or size in pixels? (and what are the numbers please?)Maximum image size has now been increased.
Paul
Thanks, Greg
Hi GregNote that one "failure mode" is AFTER the entire file is uploaded and then you get "oops, something went wrong"... so the possibility that it can be pixel size, or something else exists.
I agree with you, it is probably absolute file size in bytes, but I figured to get it "straight from the horse's mouth" - as we have said in the US for some time.
reference post 40
The touchpad can "trigger" by your palm brushing over it and the cursor will jump, this is a unique thing for laptops.
Slightly off-piste, I found out by chance that phone screens seem to be activated by heat from the finger tip. On a warm day, you can activate apps on your phone simply by the finger hovering a very small distance off the screen![]()
The timer adjustment on our cooker is like that, takes ages to zero in on the time you wantAnd even more off-piste, a few decades ago while doing work for the BBC in London I had to deal with their ultra modern lifts in TV Centre. The buttons were heat sensitive and only heat sensitive. You had to use ungloved fingers to operate, no nudging with an elbow. Often I was carrying bulky items and I became quite adept at breathing on the correct button. Looked a bit strange at first but then everyone who was carrying stuff did it and it became the norm. Another example of modern not being so efficient.
Paul
By which time you've either burnt the meal or dialled up a pizzaThe timer adjustment on our cooker is like that, takes ages to zero in on the time you want
I blame SW!![]()
Think this maybe a little topic driftLooking at the subject of this topic do I assume that you are blaming the forum SoftWare?
Paul
Think this maybe a little topic drift![]()
