New Swift Sixteen Well Wagon.
RobB
All models, boats, heli's, planes, cars, trains et
13 Dec 2009
433
2
South Wales UK
Hi Guys,
Another new wagon to show you. I'm still working on my website, so have to show it here, this way. It is 330mm over buffers, 83mm wide, weight 500 grams and will cost £30.
More pics here
http://s843.photobucket.com/albums/zz357/rbush/
Thanks.
Rob.
mike
Master at annoying..
4,467
Rossendale
its a fantastic model!:clap:
KeithT
190
Nr Manchester
That looks good - very good.
How easy would it be to fit LGB hook and loop or knuckle couplers?
bobg
3 May 2010
20,141
25
Middle Earth
Or Accy Choppers?
RobB
13 Dec 2009
433
2
South Wales UK
Hi,
Thanks for the kind comments. This is a brake down of the kit. You can see that the buffers are seperate, so you can add anything you want ;) They will come in 45mm and 32mm :clap:
Thanks.
Rob.
yb281
7
Worcestershire
www.facebook.com
Will the bogies be available seperately Rob?
Oh and what wheels do you use - thinking in terms of flange depth for the 45mm?
RobB
13 Dec 2009
433
2
South Wales UK
Hi,
The bogies are yet another thing I have new to my range but can't list until the new site is finished. As you can tell, the new site is really holding me back :impatient:
The wheel sets I use are the IP Engineering 24mm items (insulated 45mm). I have found them to be very good and trouble free.
Thanks,
Rob.
mmts
62
Essex and you dont need your passport
Thinking hat on here....(I know its dangerous!!)
I see that the side frames are separate to the bed.... so could I make them narrower by cutting the bed down equally each side??? and using sprung buffers and gauge one couplings:thinking::thinking::thinking::thinking::thinking:
Bram
Playing trains, Ballroom Dancing, Good Food & Wine
4
Knowle
It looks a damn fine piece of kit and at a reasonable price
RobB
13 Dec 2009
433
2
South Wales UK
Hi,
Yes, there is nothing stopping you from doing that. The resin can be cut with a tennon saw or hack saw, then filed and/or sanded to a flat finish :clap:
Rob.
Tim Brien
29 May 2011
2,991
281
Rob,
definately a beautiful model, as is your wiggly van. At first thought, I could see a usage for several of these, but alas, they are built for 16mm scale and around 20mm too narrow for me (83mm as against 103mm width). Pity, as a few of these with double buffers would fit in well with my Thomas rolling stock.
KeithT
190
Nr Manchester
Good point Tim,
I must run a tape over my Accucraft stock, they might be more compatible with some of those.
KeithT
190
Nr Manchester
Just run a tape over the Accucraft wagons and these should be a good match with the L&B stock but a little narrow for W&L or Manx.
Chris Bird
Steam,gardening, photography
14 Dec 2009
1,785
12
Dorset
I reckon these are going to work a treat on my railway as they will be spot on with my Swift tankers. I have to admit that I never worry about the width of specialist vehicles - and might even try the two I have on order with my 7/8ths works railway stock. The question is what to put on them? Maybe we should have a "most original load" challenge in due course.......
Cheers
Chris
PaulRhB
This Way Up
408
Wilts Drifting toward the RhB,plate tectonics rock
I would think adding strips either side of the main bit and planking it to cover the mod with balsa would cost about £5 and allow you to make them 100mm wide to match the Accucraft W&L stock and the hard work of the shape, sides and bogies is still all done for you. Might get one just to try this out :)
Trainman
All narrow gauge and industrial railways,
459
Auckland
L&B do have one at last recollection. Called a Mantrol.
PaulRhB
This Way Up
408
Well I've committed :) order sent off just got to wait for Rob to get wheels back in stock. Will start a thread on stretching it to match the W&L stock when it arrives. Gives me time to find some 5mm strip to space out the sides and suitable planks for the deck to hide the mod.
PaulRhB
This Way Up
408
One week later, and Rob said there'd be a wait for wheels, and it's here much faster than expected!
Rob was very honest about expecting to wait a few weeks for wheels so the communication and delivery early is worth 10/10!
First reaction is very neat mouldings and feels substantial so 10/10 for quality too.
Laid it out and figured out the assembly quickly, though mentioning how the tubes fit in the bogie casting, or a small diagram, on a small business card sized photocopy might be worthwhile ;) still 8/10 for that as it's pretty obvious.
So very impressed with the kit and only one little suggestion for short instructions :)
Off to buy some bits for my conversion.
Note to put the brass tube on the axle before pressing on the second wheel.
