The pipe and Expamet combined when tied together with Cable Ties would I imagine create a pretty stable structure, not walk onable like much of my line is but more than adequate. A good friend of mine used 1/2 plumbing pipe for a spiral using a boiling hot water system to get the curves he required in the pipe. He used Grey Pipe where the mag article uses blue, probably pretty similar stuff. Though I have bought the grey in straight lengths whereas I have seen the blue in coils. The spiral created was pretty stable and in many places as the soil compacted supported in mid air. In the recent 16mm society article the ground supports are spaced 4-500mm apart so a good degree of stability will be obtained by that. Ground fill will of course over time sink the surface but as the top has small size ballast that can just be filled in, though with the size of ballast on the Expamet being pretty large in this case it looks like varying fill with other material to the track side and below the Expamet may be required over time. For those unsure what Expamet is, it is used for Screed and Wall Support with Concrete and Plaster. Can be obtained from a Builders Merchant as can all the parts of this system. In fact my local Wicks could supply the whole kit and caboodle.
