Yes, that's the idea, BUT it's definitely noticeable.trammayo said:...a little quieter and more comfortable for passengers.
Even in present-day Amsterdam there's certainly a jolt as the flange runs over the raised bed.
Dtsteam said:Another inspirational piece of work, Trevor. Well done.
On the last note, there was a fixed frog at Blackpool Pleasure Beach loop which had been chewed up so much that the flanges had cut a new one, and left a little sliver of metal behind.
MRail said:Yes, that's the idea, BUT it's definitely noticeable.trammayo said:...a little quieter and more comfortable for passengers.
I do - I reckon it put more corrugations in than it took out.trammayo said:There used to be some terrible track in Blackpool. Remember when they had the running lines on the front ribbon welded? Didn't help the points though!
What only one?tramcar trev said:I'm gunna have a crack at making a set....
Neil Robinson said:What only one?tramcar trev said:I'm gunna have a crack at making a set....
Go on be a devil. I rekon you'd only need eight sets and twelve crossings to make the classic double track 90 degree junction with straight on, right and left turns for all roads!
Classically known as a Grand Union!Neil Robinson said:the classic double track 90 degree junction with straight on, right and left turns for all roads!
Interesting.... One day I was driving along some street in Sydney in Leichart and there are roadworks in progress, I get closer to the action and there are several short is lenghts of genuine Sydney tram track piled up with rubble.... in the middle of the chaos I stopped the car jumped out and asked the nearest person in a HIVIZ vest if they wanted it, "Take as much as you want" he says so I shoved a few bits in the car ignoring the hooting horns of those around me......trammayo said:Dtsteam said:Another inspirational piece of work, Trevor. Well done.
I used to collect tram track and I had a chunk (about 3 cwt) of Bradford track from a crossover. It had been nickel welded to build it up - must have been several pounds of weld. Now the only piece of track I have is a cross section, supplied by Dorman, Long & Co, to Leeds in 1936 (and its nickel plated).
It would have to be I suspect, elevated railway, 3 rail,,, reeks of Chicago....Fairlie said:Is that Chicago?
tramcar trev said:It would have to be I suspect, elevated railway, 3 rail,,, reeks of Chicago....Fairlie said:Is that Chicago?
Ahhhhhh see that why you're a moderator, such knowledge......whatlep said:tramcar trev said:It would have to be I suspect, elevated railway, 3 rail,,, reeks of Chicago....Fairlie said:Is that Chicago?
Definitely Chicago. Presumably tower 18 junction at the NW corner of The Loop.
I suspect elevated is cheaper and quicker to construct. Most US cities didn't have the space constraints of places like London which, I think has the largest underground network, and it's still growing!tramcar trev said:Ahhhhhh see that why you're a moderator, such knowledge......whatlep said:tramcar trev said:It would have to be I suspect, elevated railway, 3 rail,,, reeks of Chicago....Fairlie said:Is that Chicago?
One wonders if there is a ground water problem there outher wise I'd have thought a "subway" would have been the go rather than the "El"
tramcar trev said:I'm in my back yard and I can hear what I thought was someone playing with the points on the tramway, there was a hollow metalic clonking sound very similar to the noise when the spring loaded blades "clonk" back after a flange has run thru them...
After ensuring that there were no ghosts present I discovered it was actually a FROG making the noise. Investigations lead me to discover that it was a "Pobblebonk" of which there are numerous Tadpoles in the pond of introspective introspection.......
So here in after the sound of tramway point blades snapping back into place will be technically refered to as Pobblebonk, not clunk, thunk, thonk or clonk.... In a sentence: the points closed with a loud Pobblebonk....
Here's the said frog performing live on youtube; http://www.youtube.com/watch?v=F3ivv7pQkWQ
