New Fencing at reasonable price
davecar
23 Jun 2010
220
13
Liverpool
IMG_3140.JPG IMG_3145.JPG IMG_3141.JPG I have just completed an additional steaming area at Childwall Railway at the bottom end of my track, near to my house. I decided to add some fencing along the siding and also around the curve and across my waterfall.
The first photo shows what I used. It is called a Gabion panel which I bought from B and Q. I had never heard of this word before but I had seen many Gabions in use. It is a cage full of rocks, used in landscaping. The panels are sold in various sizes to make up the cage for the rocks. The panels I bought measured 1200mm x 300mm. I cut the panel quite easily with my electric whizzer. From this panel I got three lengths of "fencing". The cost of this panel was only £6.64 so it worked out at only just over £2.20 per 1200mm length.
I had to add a piece of timber to my log roll in order to get sufficient clearance for rolling stock. In fitting the fence I only used every forth post. I cut the other posts slightly smaller. In fitting the fence I drilled a hole in the timber and then hammered the fence in. Using every forth post made it much easier. When joining the fence I used a small plastic tie. The fencing is quite robust and of course the metal is galvanised so hopefully will not rust. I initially had thoughts about painting the fence but have decided against it. I think also it looks quite realistic.
Thought I would pass on this idea.
Kind regards,
Dave
Reactions: 8 users
Zerogee
Clencher's Bogleman
1,723
North Essex
I think that looks very effective, Dave - practical AND realistic!
davecar
23 Jun 2010
220
13
Liverpool
IMG_3144.JPG IMG_3142.JPG IMG_3143.JPG More pics.
Kind regards,
Dave
Reactions: 2 users
pugwash
impecunious pirate
17 Nov 2009
21,159
1,816
Luxembourg
Excellent idea and work, and I think you are right to leave it unpainted. :clap:
stockers
3,795
65
Nr. Ashford, Kent. England.
Reactions: 5 users
simon@mgr
Aviation, model engineering & all things technical
78
Gold Coast, QLD, The Land Downunder
Gives a professional appearance.
DGE-Railroad
The Orchard Line
26 Jan 2020
607
89
52
United Kingdom
Excellent. Thanks for sharing this. I was just doing a search for some bridge edging inspiration. This is perfect :)
JimmyB
23 Feb 2018
6,954
923
69
Weston-super-Mare
www.tumble-down-falls.co.uk
As this is an old thread (before I started in G Gauge), I had not seen it, and I agree it looks the part. Does anybody know the wire gauge, and mesh spacing.
DGE-Railroad
The Orchard Line
26 Jan 2020
607
89
52
United Kingdom
From what I've read, the holes in Gabian mesh panels tend to be about 3"x3" (76mmx76mm) and it uses 3mm / 10SWG wire
3,524
Put a LGB driver figure in your pocket, then go and visit any of the big DIY 'Sheds'..
They will all have galvanised mesh panels, in various sizes. - Both panel, and 'hole-size'.. - Personally, I think those which are rectangular, look better than square?
<edit>
If you have not got any: Get a decent pair of big tin-snips, or (better) small bolt-croppers. - So much easier on your fingers!
DGE-Railroad
The Orchard Line
26 Jan 2020
607
89
52
United Kingdom
The new builds on the edge of our property had gabian walls put in beneath their gardens to aid drainage. I wonder if I could use the bolt cutters on them to obtain some fencing, without letting any of the rocks out... :giggle: :p
