Graham
In Smoggy Land
Well after some head scratching and experimentation the final result, the Bank of POP and MOM for my western town. Due to limited space the buildings will be foreshortened to a sort of relief concept. It was created using my Stepcraft CNC machine to create the brick pattern with a polished 1mm domed projection turned out of some 3mm silver steel. A lot of fiddling was required to get just the right depth for the indentation of the brick shapes otherwise the surface of the board ripped through to the foam. Finally settled on 0.3mm in three passes.
Next challenge is the painting. First thoughts are to spray the whole thing with a dark gray Tamiya primer before sponging on the brick colours.
