Been away from the forum for a while and didn`t have so much time for the hobby last season, but I am sure that my new (2012 purchase) M-LGB Rugen should perform far better than it does, so I would like to consult the experts here. It is ultra sensitive to dirt on the track; it will stop where other locos pass freely, but will then pass over that place OK after I have cleaned that point on the track with my LGB cleaning pad. My brother in law opened it up and felt it had been somewhat over-lubricated, and cleaned it; however I think it has always performed like this, more or less. In particular, it isn`t responsive to the analogue throttle, i cannot get it to smoothly and slowly pull away on a a standing start by gradually opening up the throttle- sometimes I have to go straight to full power to get any life out of it. The motor seems fine though, it pulls good loads up the inclines with no wheel slip.
Surely I should expect better from such a relatively expensive model? It looks lovely, the sound is great, and it is strong enough, but its a bit much to have to constantly prod it into movement while my Stainz will happily trundle around for a couple of hours.
Anybody have this model, or recognise the general symptoms? Any remedies? As you can see, it has no skates and one tyre. Which are the crucial wheels to keep clean - or are all wheels involved in pick up?
Also a general question, - where do you apply lubricant on a loco like this? My BIL said only on the piston rods, not on the axles. And where would you apply lubricant on a diesel such as my 2091?
