Having read richand26mhz’s thread about problems switching on lights with MTS 3, I thought I’d share my own experience.
I started with a Passenger Set nearly 20 years ago and soon got interested in DCC control. Though not having a permanent layout, I slowly collected various parts, mostly via eBay, and now have 4 locos, rolling stock and a good bit more track. I also acquired an MTS 3 Central Station, two 55016‘s and a 55015 controller. Two of the locos are stock LGB DCC equipped and while I could control them I could not get the lights to switch on unless on analogue power. With time to spare in lockdown, I’ve fitted a 55021 decoder in the Stainz I got with the set and this had the same issue - no lights or smoke. Trying to read and understand the CV’s with the 55015 isn’t straightforward and any attempts to change values to get the lights to work were unsuccessful.
Annoyed at not getting functionality, I was tempted to go the battery route but have kept struggling on and have now acquired a 55045 programmer. This gave me a full read out of the values in each loco and there seemed to be nothing untoward. I tried changing various values but no change. Searches on line only suggested switching off the analogue control function and ensuring 14 speed steps were selected.
richand26mhz found an issue with his MTS 3 where it had previously been used with a DiMax controller and was “remembering” all the previous addresses having 28 speed steps and I guessed mine, having been bought second-hand, had the same issue. There are no clues anywhere as to how to clear the MTS 3 memory and I tried various button holding/power off sequences to achieve this but without success.
As a last resort and out of curiosity, I changed the speed steps on my Porter 0-4-0 to 28 and was given a red warning on the MTS software saying that LGB did not support 28 speed steps, wrote the CV’s to the loco via a programming track and, bingo! it worked. The lights switch on and off with button 9 and follow the direction of travel. I have read back the CV’s and this confirmed it is using 28 speed steps. Throttle control is normal and the lights are stable. I have since changed my other loco and the Stainz to 28 speed steps and both are now working perfectly with the smoke working on button 1 too.
Everything everywhere says this isn’t right?
2
- Show all
