Motor for Aristocraft Class 66
486
Tamworth, Staffs.
Title say's it all..
I am in need of motor for the Aristocraft Class 66.
I need to remove (and strip-down) the bogie, but I have a loco which draws 3Amps-plus, and a smoking motor! :eek::(
Possibly, our Friends States-side, will have more luck in locating one of these?
Thanks,
PHilP.
ntpntpntp
ntpntpntp
19
56
UK
Same motor block as the SD45 of course, but not much evidence of any of these being around either - only "sold out" messages.
Can the motor be stripped down and the commutator serviced/cleaned, or has a coil insulation failed maybe?
You'd think there must be a motor out there of similar spec, I doubt the Aristo motor was specifically made for them.
486
Tamworth, Staffs.
Except they were made .. ?30-40? years ago.. ?? :eek::(
Perhaps, Greg'knows a man who would know? :think:
I *suppose* if all-else -fails.. I can strip both bogies, Leave the centre axle free-wheeling, and drop four axle-hung units in?? - That would give me four powered-axles. Get round the articulation problem. AND probably get rid of that 'orrible whirring noise they make.. :think::think::)
I wonder if G-Bits might have one?? :think:
Rhinochugger
Rhinochugger
Retired Oik
546
North West Norfolk
Fosworks used to sell the nose hung motors :nod::nod:
ebay mike
ebay mike
6 Dec 2011
2,464
193
Norfolk
PM on it's way.
Greg Elmassian
Greg Elmassian
8 Mar 2014
2,867
171
San Diego
www.elmassian.com
I'm not completely knowledgeable about the trucks on that loco, does make sense standard 3 axle Aristo truck.
I might do know a guy, but to be sure can you give me the axle spacing, and also the tread diameters?
I might also know a guy with stainless steel replacement wheels, although they have finer flanges, so could be a problem on some trackwork.
Phil send me an email, let's see what I can do.. my suggestion is pull the motor block apart, if you have not ever done so, I have a page on them on my site, under MOTIVE POWER... ARISTO .... PRIME MOVER
486
Tamworth, Staffs.
Thanks Guys..
Will contact you a little later.
Tony Walsham
Tony Walsham
10
Casino, NSW
I think you will find the standard 3 axle AristoCraft motor block has two motors, making the loco four motored.
This might be helpful when working on the motor block.
486
Tamworth, Staffs.
Yep!
Two motors, and three gearboxes..
I can't quite field-strip them blindfold.. But I do seem to have taken many of them apart to clean / lubricate.
Greg's page is invaluable, the first couple of times.. :):rock::clap::clap:
Greg Elmassian
Greg Elmassian
8 Mar 2014
2,867
171
San Diego
www.elmassian.com
The tricky part is unsoldering the motor tabs without melting the motor block housing and/or damaging the motor brushes by overheating the tab.
I updated my web page to specifically address disassembly, I noticed I had not done this, and I also cleaned up the page a bit.
ntpntpntp
ntpntpntp
19
56
UK
When did Aristo fold? Not 10 years ago yet, is it? I certainly didn't buy my 66 and SD45 30+ years ago
Rhinochugger
Rhinochugger
Retired Oik
546
North West Norfolk
Yebbut nobbut - some of Aristo's offerings were not upgraded, but some were. I think the SD45 had an upgraded gearbox because it was a newer model, the C16 was rev-vamped, but I'm not sure how many others were, and as per Phil's comment earlier - 2 motors, 3 gearboxes - those would have been the original design I think.
Greg Elmassian
Greg Elmassian
8 Mar 2014
2,867
171
San Diego
www.elmassian.com
The SD45 was the first loco with the "prime mover" type of gearbox (the modular gearboxes driven by a hex shaft with the sliding axles
... Aristo always called it the "prime mover" type... so I keep calling it that type.
It is a completely different design from their 2 axle diesels and the steamers... The modular gearbox was introduced to their steamers with the second version of the Pacific.. or the first version of the Mikado, not sure.
from my site: (might be a few errors)
A short chronology of Aristo diesel production:
1988 - Aristo FA1
U25B -
1996 - RS3
1997 - Lil-Critter
1998 - CenterCab
2001 - SD-45
2004 - Dash-9
2005 August 4 - Consolidation - first mention
2006 - RDC-3 - originally talked about
2007 - E8 - delivered
2008 summer - 0-4-0 Live steam - promised
2008 August - GP-40 second run - promised
2008 late - RDC-3 - promised
2008 late - E8 - second run - promised
2008 late - Consolidation - promised
2008 - GP40
2009 late - PCC Car- promised
2010 - SW-1 switcher first promised - never made
2010 - January - 0-4-0 Live steam - Delivered
2010 summer - Aristo-Craft RDC - promised
2010 - July - RDC-3 - delivered
2010 October - Aristo-Craft RDC - delivered
2011 - January - PCC Car delivered
2011 - Consolidation - delivered
Hutch
Hutch
G Gauge, Raising Peaches, Apricots
1 Feb 2012
371
7
Southwest Oklahoma, USA
Hard to believe my FA-1's with the end play adjusting screws are that old.
Street prices were quite reasonable when those were introduced.
---Hutch
486
Tamworth, Staffs.
Just a quick update..
A lot on here at the moment, so it will be the weekend before I can drop the bogie, measure, and investigate further..
Thanks Guys!
funandtrains
funandtrains
20 Sep 2011
3,754
7
50
Croydon, Surrey
Bachmann now sell the 2 axle trucks, I'm not sure if the motors are the same or not.
