Full track power, which I take it to mean "normal" DCC mode is AC, alternating current... which will make a DC motor buzz and eventually overheat and melt itself.
There are some older systems that allow "address 0" which changes the DCC signal from a symmetrical square wave to something called "pulse stretching" and they make the waveform assymetrical, i.e. the positive part of the AC waveform is much longer than the negative part, and thus the DC loco sees "mostly" positive. It sort of works, it is noisy, and it can result in additional heat.
If you are trying analog mode, i.e "address 0" you should not be doing it with a decoder.
I hope this makes sense, don't know what your level of expertise is.
